Tractor Talk Discussion Forum
How many gallons in 8.3X24 tires?
Chris Jones
08-27-2003 15:08:16
Can someone tell me how many gallons 8.3X24 tires will hold so I can determine how much antifreeze I need to buy to fill my tires. Also if anyone knows the mixtures of methanol to water used I'd appreciate that as depending on cost and mixture I might go that route. Thanks.
Alberta Mike
08-28-2003 05:58:08
 Re: How many gallons in 8.3X24 tires? in reply to Chris Jones, 08-27-2003 15:08:16
I have a chart here that says that you'd need 12 gallons (I assume US gallons) for an 8-24 tire, that's as small as the chart gets. The 9-24 uses 15.6 gallons. Those figures are for "water only" which would be the total volume if it were a mixture like you're planning.
720Deere
08-27-2003 16:03:22
Try this link: www.tractorsmart.com/Farm_Tractor_Liquid_Tire_Ballast.htm
That should tell you the tire capacity. As for the ratio of antifreeze, try this one: www.gulflubricants.net/pb/841115_16_Gulf_Premium_Blend_&_Premix_Antifreeze_PB.pdf
We have been using antifreeze for close to 20 years in MD. As I remember, we use about a 3:1 water to antifreeze mix. You only need protection 10 to 15 degrees colder than your coldest winters.
Dieselrider
08-28-2003 05:06:17
 Re: Re: How many gallons in 8.3X24 tires? in reply to 720Deere, 08-27-2003 16:03:22
Do you kmow of any place that compares the weight of the antifreeze with the same vokume of calcium chloride?
720Deere
08-28-2003 06:36:34
 Re: Re: Re: How many gallons in 8.3X24 tires? in reply to Dieselrider, 08-28-2003 05:06:17
That is the one drawback to antifreeze, it is lighter than straight water. Calcium chloride can get the liquid weight up to 10 - 12 lbs per gallon easily. Antifreeze mixtures are only going to weigh around 7 lbs/gal.
Chris Jones
08-28-2003 07:37:48
 Re: Re: Re: Re: How many gallons in 8.3X24 tires? in reply to 720Deere, 08-28-2003 06:36:34
I'm pretty sure antifreeze weighs more than water--a little over 9 lbs per gallon as opposed to 8.3 or so for water. Methanol probably weighs less. And yes Calcium Cloride is heavy but the down side of corrosiveness is a trade off. I'd like to see a table on the web listing weights of various fluids but haven't found a good one yet. I'd also like to know what percentages of methanol to water result in what freeze level. Anyone know of any helpful sites?
