Tractor Talk Discussion Forum
How to bushhog a field?
Mark
08-26-2003 11:45:24
If you have an irregular shaped field and you want to bushhog it, do you keep going around it or do you take the longest side and go back and forth after cutting out a couple of rounds?
Ray,IN
08-27-2003 21:05:25
 Re: How to bushhog a field? in reply to Mark, 08-26-2003 11:45:24
I might add that if you drive in the direction to make the rotation of the blades cut into the bent over grass from the inside tire, it will better pick up the bent over grass and cut it much closer than than if the blade rotation is the same as the direction of the bent over grass. Slower ground speed makes better cutting, leaves less uncut stuff, and is safer work.
Adam B.
08-27-2003 16:51:25
The only ones I've run have been either 15' or 20' models. Those of course have fold-up wings and three knife pans with two blades each. The wing pans are positioned behind the center one, so they can overlap the what the center blades cut a little bit. What I've found is that this arrangement can leave streaks when mowing on a curve, because there's a gap that isn't overlapped when the mower is making an arc. For that reason, we typically make three or four rounds, then either set up lands and cut, or just start on one side and turn right around at the end of the row to mow a strip next to the one we just cut.
If you're talking about using a smaller, single pan chopper, then don't mind me.
Huckleberry
08-27-2003 06:37:22
Go around your field enough times so that you don't have to cramp your tractor too much on the turnarounds. Go very slow when opening your field up. Be prepared for obstacles, drop offs, and so on. Watch out for big rocks that can break your blades. Don't get in a hurry ~ and even new bush hogs seldom leave a smooth golf course scenario. Be careful and have fun.
Indydirtfarmer
08-27-2003 04:52:12
Make 3 or 4 rounds around the outside of the "field". Then, make a straight line from side to side, or corner to corner, which ever makes the longest run. Then just do whatever keeps the mower cutting the most. do the least amount of turnig as possible. Whenever the mower isn't cutting, you're just riding around. Keep your rows straight. It just looks better.
Mow about a million acres. Nothing like experience.
Mark
08-27-2003 06:43:51
 Re: Re: How to bushhog a field? in reply to Indydirtfarmer, 08-27-2003 04:52:12
Hey Indydirt, You said exactly what I wanted to hear. My partner who is a college graduate majoring in agriculture with 35 years farming experience says to bushhog on all sides (or go round and round the field). Seems to me like he turns too much. This has caused heated discussion between us.
stan
08-27-2003 01:01:07
Every body does things a little different. I mow one direction, and come back the same way overlaping the bent grass this kind of pulls the bent weeds and grass back up. This makes for a little extra turning, but the end result is a good looking mow job. You need to keep the blades sharp also.
ted
08-26-2003 21:59:03
What seems to usually work the best is to mow in circles, throwing the cut grass to the outside. So that when you make the next pass, you arn't picking up the extra cut grass, and have more of a chance of picking up the tire mashed grass. We have a 6' chopper, same with as the tractor, so we just overlap a little to help pick up the mashed grass. An 8' you just have to deal with it. You can go in circles around the entire field or divide it up into lands, whatever seems the quickest for the size of the field and the amount of turning.
Joe Evans
08-26-2003 20:51:05
As has been suggested before, and can't be stressed enough, "walk down" the field first. The time spent doing this quite possibly will pay for itself ten-fold in the long run if you encounter hazardous obstacles and your rig is down for two days for repairs and $$$.
Open up the field first by mowing two or three rounds around its perimeter. Then mow in straight lines in the direction that the field is longest (assuming a roughly rectangular field).
If the field can be seen by vehicles from an adjacent road, make your mowing lines perpendicular to the road if practical. Bush hogs or single-spindle rotary mowers of that nature are not the cleanest cutters around, and the cut quality will, most of time, correspond to the height of the stuff you're mowing. Bush hogs will tend to leave a strip of partially cut stuff standing. Most of that can be attributed to the tractor's wheels flattening the grass down with the mower's knives skimming over the bent over stuff. When the mowing swathes are viewed from a sideways direction--looking across the swaths instead of viewing them down their length--you will tend to see the uncut stuff more. Looks like dirty mowing job.
You can also "mask" a mowing job that is not perfectly clean by keeping the swaths straight. Say your mower is leaving a dirty strip 8" wide. If you keep your swaths straight, that 8" will not be too noticeable a couple hundred feet from a viewer's eye. If you're swaths meander 6' side to side, that dirty strip will not look like a strip--it'll look like you're operating a mower with no knives at all.
Straight lines are easy to do. When starting out across a field to establish your first swath, pick out an item on the far side--a fenced post or tree. Aim dead for it by looking right at it. Maybe line up your radiator cap or hood ornament on the target. Do not look up, down, or back for any length of time. This is where your initial walk down pays off because you want to be able to cross the field with confidence. I suggest a dry run where you think you want to make the first straight line. Sometimes your lines may tend to get a bit snakey, but you can adjust the curves out on subsequent passes. Keeping you lines straight keeps things interesting and keeps the boredom down. I'm utterly amazed at how crooked some mowing jobs are. Look like crap on a white duck.
There. I've been wanting to blather about this for a long time to anyone interested in listening. Scope out the field first and have fun!
rod
08-26-2003 18:53:48
first walk it over see what is in it this is what my neighbor found in my field when he hogged it big roll of page wire fencing that was in the ground, some nice old rubber hose from an old gas pump that wrapped tightly around the stump jumper, steel pins from old rotted phone poles, rocks that go like cannon balls and a nice big in ground hornets nest and yes he still talks to me but does not mow the field anymore
regards
rod
Bus Driver
08-26-2003 15:48:12
If the tiny improvement is worth it for your situation, look at the direction the blades turn on your machine. Then mow so that the blade will pick up the stuff your tractor tire mashed down on the previous round. But even then, it won't get it all.
rustyfarmall
08-26-2003 12:18:34
With a bush hog it makes no differance, you could drive in figure 8s if you wanted to.
Van(WA)
08-26-2003 11:57:49
Mark; I always go in the same direction that the field has been worked (plowed, seeded, ect) if never been worked,I think I would go in a circle direction, should be faster, whatever is easier for you!
sparky
08-31-2003 17:09:05
 Re: Re: How to bushhog a field? in reply to Van(WA), 08-26-2003 11:57:49
I've got and old five footer, works best if I mow in counter clock wise circles trying to re mow what has been kicked to the left.
