Tractor Talk Discussion Forum
Gas/Fuel guage check
Wayne Woods
08-24-2003 19:37:24
Can someone post directions or instructions on how to check out a fuel/gas guage? I have two that don't work, and I'm getting tired of guessing how much is in the tank. (One has a curved filler neck, so you can't see to check, the other has a tapered and stepped bottom, so even looking down into the tank doesn't tell you much. Need to get those fuel guages fixed!
Thanks
jim
08-25-2003 05:58:51
 Re: Gas/Fuel guage check in reply to Wayne Woods, 08-24-2003 19:37:24
Believe it or not , here in Canada , some cars (I believe mostly GM) have had their fuel gauges damaged by an agent in the gasoline ( I believe either Shell or Petro-Canada). I believe the problem is being corrected by either the car company or the refiners. Just thought you would like to know.
Rod F.
08-24-2003 20:32:41
If it is an electric gauge, just find the resistance specs for the gauge and sender. Pull the sender and check that. Most will probably run a range of 15 up to 250 ohms, with a steady ascent or descent through the range. If the descent is even, I wouldn't worry too much about the exact values. The gauge will have a similar range of values, depending on the location of the indicator needle. Also check all the wires in the system. I recently had a bad sender. Some of the wires were busted in the rheostat. It would read to a certain point, then the circuit would open. You might find a similar problem. Good luck.
Rod
Farmer John
08-25-2003 10:13:51
 Re: Re: Gas/Fuel guage check in reply to Rod F., 08-24-2003 20:32:41
Use a match...LOL
Rod F.
08-25-2003 14:15:40
 Re: Re: Re: Gas/Fuel guage check in reply to Farmer John, 08-25-2003 10:13:51
I assume you've never tried it?
