Tractor Talk Discussion Forum
Charger/Starter Units-Work for Tractor?
Paul Butler
08-23-2003 03:54:53
I am looking at these 2/10/50 amp trickle chargers to put on my tractor for the winter (John Deere 4630-also for use on a 4400 combine).
I noticed that for about $150 I can get a charger WITH starter. It can provide a 450 amp boost. They come with a 6v/12v switch so it should work for either batter.
Would 450 amp be enough to spin the starter on a 4630?
Jeff
08-23-2003 21:57:41
 Re: Charger/Starter Units-Work for Tractor? in reply to Paul Butler, 08-23-2003 03:54:53
The best battery protection units
are from vdcelectronics.com
Dont mix battery maintainers, and boosters.
You'll never get the best of either...
I have the VDC battery maintainers on most
everything I own, and batts have lasted for
years without sulfation.
Chris
08-23-2003 06:16:41
If size is not a concern I would go with the one with the 450 amp boost.Some of them are a bit heavy. It is a feature you would miss if you did not have it. Won't spin up an engine on its own but if the battery has any life in it they usually will make them go.
Nebraska Cowman
08-23-2003 04:21:15
not by itself. It is as you say, a boost
