Tractor Talk Discussion Forum
P/S swap on JD 70D
Mike
08-22-2003 10:45:13
was wondering if any P/S unit off of a 2 cyl tractor will fit my JD 70D (which doesn't have it). if not which ones will? I have a salvage yard close by with a couple of tractors that have the units on them and said he would make me a good price on one if it will fit. will it add or decrease value of tractor in future years?
Brokenwrench
08-22-2003 14:54:33
 Re: P/S swap on JD 70D in reply to Mike, 08-22-2003 10:45:13
To do it correctly,you will need a donor tractor to remove the steering post,pump and lines to retain originality. This method will add value to the tractor from an originality standpoint if you are going to restore the tractor. The add on units(I,m assuming this is what you are refering to) will make the tractor easier to steer and can probably be adapted to your tractor. From a working tractor standpoint it probably won't hurt the value. But it won't increase the value if you are going to sell it as a restored tractor.JMHO
mike
08-23-2003 14:33:20
 Re: Re: P/S swap on JD 70D in reply to Brokenwrench, 08-22-2003 14:54:33
thanks, now I have to find out what he called a good price. :-):-)
