Tractor Talk Discussion Forum
Farmall C
George
08-17-2003 09:41:12
Hello every one: I have been attempting to identify 2 farmall C tractors that I now own as to what year they actually are. In the serial number lookup it states that the serial number is located on the left side of the trans or diff housing. My dilema is that both tractors serial numbers have their plate on the right side of the tool box (seat support) one number is 76711 and the other nuber is 74367. These numbers seem to indicate that the tractors were made in 1951 or so. The 76711 tractor was boughten new by my grandfather and when I was a kid I remember seeing a manual for a 1948 farmall C in our old basement...and have always believed that it was a 1948 tractor but now I am confused as some of the information indicates otherwise. I can't go back and find the book nor can I ask my father or granfather as they have passed away. Can anyone help me figure it all out? the only thing I am most cetain of is that they are C's and not super C's .If any one can help...I would really appreciate it thanx Geo.
roastnear
09-01-2003 18:54:50
 Re: Farmall C in reply to George, 08-17-2003 09:41:12
acording to my book they are both 51 modles i have a 50 and the serial # 66100 to answer your question about the manual I.H didnot always send small dealers complete paper work it could be the tractor came wihtout a manual and the dealer had an extra from 48 they would be more or less the same also the c serial plate is on the seat base or some call the tool box Rostnear
Dave_Id
08-17-2003 09:54:14
The Farmall C plate is on the battery box.. The M & H were on the trans housing.. Check the motor ser. # on the milled flat near #1 spark plug, if this number is close, then go with the year you find on this site. You can also check casting dates on your castings 8*14*T would indicate the casting was cast on August 14th, 1950 . U & W were used in 1951, V was not used.
Dave_Id
08-17-2003 15:21:15
 Re: Re: Farmall C in reply to Dave_Id, 08-17-2003 09:54:14
Just curious, if you have a later 1951, do you have a factory C123 motor in it instead of the C113? The later ones were supposed to have the 123
