Tractor Talk Discussion Forum
4020 pto noise
Kraig
08-14-2003 20:43:30
I was mowing today with the 4020, 1000 RPM shaft. When I turn right more so than left there is a terrible rattling noise, it seems right under the operators seat. When turning left it is not nearly as severe of a noise, What should I look for?
Brokenwrench
08-15-2003 04:50:22
 Re: 4020 pto noise in reply to Kraig, 08-14-2003 20:43:30
Is the distance from the drawbar pin to the end of the pto shaft correct, check the manual for your piece of equipment and see what distance it specifies. There is a different dimention for 540 and 1000 rpm operation. Is the pto shaft in line with the drawbar?What you are hearing is driveline noise carried through to the gear train of the tractor. You are either collapsing the slip yoke completely on a turn or turning the driveshaft at too severe an angle. The noise is not good for your mower or the geartrain in the tractor
chris
08-14-2003 20:49:03
Check your mower pto shaft, sounds like your ujoints are going out.
