Tractor Talk Discussion Forum
Tire question
Randy Toole
08-14-2003 18:51:37
Just had a rear tire replaced for my Ford Jubilee and did not notice until after I put the wheel back on that the tire store installed it backwards! Since I use my tractor only for fun on regular paved back roads, will this backwards mounted tire wear more quickly in its current position? Thanks in advance for any replies. R Toole Orlando FL
Don LC
08-16-2003 06:34:22
 Re: Tire question in reply to Randy Toole, 08-14-2003 18:51:37
Call the tire co. and tell them you want the tire remounted..... if you are going to do it, do it right..... .
jw 57
08-15-2003 18:35:15
Take it back and have them mount it right.To invert a wheel will make a bad situation worse as the geometry will be out.
Greg Miller
08-15-2003 06:27:43
i would think that the tires facing opposite directions would produce a horrible ride on pretty much any surface. take it back and have them remount it.
stan
08-15-2003 00:56:08
I think they should be both installed the same direction, and the shop should do it with out and problem. I run my tires backwards on my tractor I use for mowing because I need extra traction backing up banks, I dont do much road driving but when I do I dont notice any problem.
buickanddeere
08-14-2003 23:05:26
Driving on paved roads with the tires mounted backwards sharpens the lug. Now mounting them properly for pulling, gives near cut tire performance without getting DQ'd.
Shane
08-14-2003 21:03:48
If the tire was on the rim when you took it in then I would make them reinstall it correctly. They got paid to do it right and will probably have no problem redoing it, hopefully anyways. Good luck
Sid
08-14-2003 20:13:37
I think that tires on backward have a funny feel running them on pavement. The people I know that run combine tire on backwards are working in muddy conditions and it is so that they have a better chance of backing out of a muddy spot and not damaging the crop.
markct
08-14-2003 19:32:52
well actualy alot of guys say that when they run equipment on the road alot they will install the tires backwards, i have been told that is part of the reason that some custom operators put there combine tires on backwards, i personaly have no experience with running the tires backwards, i dont put enough road miles on my tractors to worry about it. i dont think it will do any harm to your tire, it wont perform very good in mud, but on pavement i dont think it makes a difference, but it does look awful silly, so if the tire shop doesnt want too much to remount it the right way i would go for it just so ya wont be ridiculed by your tractor buddies for years to come.
SHANNON
08-14-2003 23:58:44
 Re: Re: Tire question in reply to markct, 08-14-2003 19:32:52
just try put the other tire on other side and other tire to other side.. then it will be point like its supposed to, almost like flipping around the rims/tires.. it works on mine.. not sure if yours can... hope that will work and save u trouble...
kypete
08-15-2003 00:19:11
 Re: Re: Re: Tire question in reply to SHANNON , 08-14-2003 23:58:44
You'll still have one on backwards.
bob
08-15-2003 12:00:39
 Re: Re: Re: Re: Tire question in reply to kypete, 08-15-2003 00:19:11
Wouldn't have to. If they're the type that dish out, one tire would be close on one side & farther out on the other side.
