Tractor Talk Discussion Forum
Need info on updraft carb for continental engine
jgolden
08-10-2003 14:55:28
My brotherinlaw is rebuilding a continental F6-209 engine in a Clarke fork lift.It has no carb. He was told that it was an engine that was used in a number of older tractors. Any info on a source for an updraft carb or tractors that used the same engine would be appreciated.Thanks.
VaTom
08-10-2003 16:07:19
 Re: Need info on updraft carb for continental engi in reply to jgolden, 08-10-2003 14:55:28
Hi J.,
I don't know much about the differences of Continental engines but I have an updraft carb from a 6 cylinder around 230 ci IIRC (early 50's Linkbelt crane). Ventilated block is here somewhere, probably with a number on it, but I took off the carb attached to the intake manifold which is bolted directly below the exhaust manifold. Anyhow, you're welcome to it if you think it'll fit. It was working when the engine blew up a couple of years ago.
Give me a yell at mtncats(at)planetcomm.net but don't forget to type it @.
VaTom
jgolden
08-11-2003 11:38:47
 Re: Re: Need info on updraft carb for continental in reply to VaTom, 08-10-2003 16:07:19
Sorry I had it backwards he is looking for a downdraft carb. Thanks again
