Tractor Talk Discussion Forum
coil replacing a magnito
Dave
08-09-2003 19:24:41
would anyone know how to replace a bad magnito in a Farmall 'M' with a 12 volt coil ??? and how do you hook it up???
Thanks
wh
08-10-2003 06:36:48
 Re: coil replacing a magnito in reply to Dave, 08-09-2003 19:24:41
take the top off your mag coil. cut the wire going from your coil to the condenser. cut it "clean" and cover it if possible. put he top back on the mag. mount a coil anywhere it is handy. i made a small bracket and put it between the oil filter and mag. run your wire from the switch to the coil an dfrom coil to the terminal on the outside of your mag. you will need to either buy a coil with internal resister or put one between your switch and coil to get the current back to 6v. have a setup like this that was done about 30 years ago and still works liek a top. wade
TimC
08-09-2003 20:22:47
Remove existing coil. Run wire from points out the back case where points are mounted to where the old coil was you threw away. Come out the side of the mag thru what is I believe is an access hole up to the coil. Mount a condenser next to the access hole and attach the points wire and condenser wire to the negative on the coil "provided you are 12v negative ground". Run 12 positive thru on off switch to positive on coil. Condensor has to be grounded "hence mounting to the old mag or any other proper gound".
Bob
08-09-2003 19:41:52
Email me directly, and I'll forward a diagram to you tomorrow.
