Tractor Talk Discussion Forum
Damage generator if you run without battery?
Tom
08-07-2003 10:08:05
If you run a tractor with a magneto without a battery installed will it damage the generator and/or regulator?
thebigron
08-08-2003 19:56:28
 Re: Damage generator if you run without battery? in reply to Tom, 08-07-2003 10:08:05
Of course not, Tom. How many times have we had a poor connection at the battery post? Same thing as no battery.
Bus Driver
08-07-2003 16:32:07
Of course the owner's manual would be the definitive source of information. One of my tractors, 6 volt generator, has a caution in the
manual advising not to run without a battery. Many alternators will be very quickly damaged to the point of requiring repairs if operated without a properly connected battery- the condition is called an uncontrolled open. So I do not run without a battery on my tractors.
Jake
08-07-2003 15:11:13
Sheese!!! Don't any of you guys responding to Tom read your owner/operator manual? Generators are NEVER to be run battery disconnected. They will build up extremely high voltage and burn out themselves. Most of the op manuals say which wire to disconnect. Usually it's the field wire so that the field winding can not power up to make generator start charging.
Bob M
08-07-2003 13:36:19
I've done it many times. As long as there's no load on the generator (tape up the ungrounded battery clamp so it doesn't become grounded, and leave the lights off) it won't hurt a thing.
buickanddeere
08-07-2003 11:14:47
Not likely to damage the generator but electrical loads will see higher/lower voltage spikes. Running an alternator equiped machine especially with electronic loads is looking for trouble. More problems with low or no electrical loads when when run without a battery. If everything is turned on the spikes will be dampened and regulation will be better.
Tom
08-07-2003 12:19:45
 Re: Re: Damage generator if you run without batter in reply to buickanddeere, 08-07-2003 11:14:47
Will not be any load. Will start with a crank.
buickanddeere
08-07-2003 16:06:44
 Re: Re: Re: Damage generator if you run without ba in reply to Tom, 08-07-2003 12:19:45
Lights and guages?Are you trying to save weight for pulling or too "economical" to purchase a battery? Hand cranking a distributor/alternator engine is impossible. Hand cranking a generator/distributor engine is nearly impossible. If equiped with a mag, then ok.
ed
08-08-2003 10:11:41
 Re: Re: Re: Re: Damage generator if you run withou in reply to buickanddeere, 08-07-2003 16:06:44
Man, I wouldn't hand crank it if I could avoid it.
For $50 I'd go out an get a 12v battery. Only hook up the starting circuit that way you don't have to do a conversion. You probably will only have to charge the battery a couple of times a year and save your arm and start a lot faster.
Regarding the generator,
1.)Overvoltage shouldn't be a problem if the regulator is working
2.)Insuring the battery terminals are insulated from the frame of the tractor is a good thing (assumed you would do this).
3.) I would doubt that voltage spikes would hurt anything - well maby the lights. Old tractors really don't have much of an electrical system. Starter, lights and generator. Your mag is self contained and produces it's own electricity. Grounding the P lead turns off the tractor.
Red dave
08-07-2003 10:30:00
Yes, a generator shouldn't be run without having a battery on it. Most manufacturers recommend disconnecting it first, or you could just take the belt off of it.
My tractor is 63 years old, it has a generator and a magneto and both work just fine.
ed
08-07-2003 10:16:38
Tractors using a mag are on the older side. I'll bet the generator probably dosen't work anyway.
Unless something else is wrong I don't believe you would damage anything by running it without a battery.
