Tractor Talk Discussion Forum
John Deere A with a motor knock
johnboy25
08-05-2003 12:03:03
I am thinking about purchasing a John Deere A which ran good, but developed a slight knock. Waht could it be? I am 14 and don't know much about tractor engines. I am used to helping my uncle paint antique tractors.
JK-NY
08-06-2003 19:23:42
 Re: John Deere A with a motor knock in reply to johnboy25, 08-05-2003 12:03:03
Ck for loose flywheel like other post said. Sometimes if they were run loose too moch the splines wear and you cant keep them tight . If it is a rod you can take out shims as needed. I would seek your uncles advice. If he doesnt know the answer Im sure he has friends that would be glad to help. Good luck.
brett
08-06-2003 15:39:55
Hey im another younger tractor nut which i am 16 and i own a 1937 JD A which is my favorite. i got my tractor from my grandpa which he had since he was 35 so its been in my family for a wile. hope oyu get it fixed and hope its not to much trouble.
best luck on everything and have fun with the old girl if you get her.
RAB
08-06-2003 00:14:25
Have you solicited the assistance of your uncle? He may well have a wealth of experience into which you can tap, and be in a position to offer practical help when situations like this arise, along with recognising other potential pitfalls into which you might otherwise fall.
Regards, RAB
Ron
08-05-2003 19:15:30
It is not uncommon for the flywheel to get a little loose, and it MUST be tightened up to stop the knock--or it will wear the splines on the crankshaft... To tighten it up, I would oil the flywheel bolts and loosten them a little....then tighten them up... My Dad always said it should take 200 lbs on the end of the wrench... ( I remember him standing on the wrench)...!! Anyway.....get them well tightened--evenly..!! The flywheel also sets the end play on the crankshaft, so check that before you re-tighten the flywheel....!! Too much end play, and you will have a knock...endplay should be somewhere around .010" (ten thousanths)
Robert
08-05-2003 12:18:57
The "knock" could be anything from a loose flywheel (grab the flywheel while it's NOT running and see if you get any movement in or out), to low oil pressure (it should read in the M range if it's an original gauge, or about 20 psi if it's aftermarket, with the engine running at a fast idle), to worn rod or main bearings, which is a lot of work and money. You might also check to see that it has enough, and proper grade oil.
Sorry this isn't much to go on, but it's a start. Check oil level, then flywheel, then oil pressure. Those are the simple things to check, and fairly easy to correct. Internal engine repairs sound like they might be a bit beyond your current understanding.
Hope this helps, and good luck!
