Tractor Talk Discussion Forum
JD 2020: Fuel in the crankcase
Steven Welch
08-01-2003 20:27:30
The crankcase on my tractor is full of diesel. Someone suggested that the fuel pump was bad so I replaced it and then drained and re-filled the oil. Ran the tractor for a short period, but stopped when fuel started coming out the crankcase vent. Anyone have any idea where to start
Steve - IN
08-02-2003 06:25:00
 Re: JD 2020: Fuel in the crankcase in reply to Steven Welch, 08-01-2003 20:27:30
Steven,
One other possibility --
The early 1020's and 2020's have a hydraulic pump bolted up to the engine's front timing gear cover. If the backside seal for this pump lets go, it can pump a gallon or two of hydraulic fluid into your crankcase in less than five minutes.
The seal is still available from JD, and runs around 4 bucks.
If it's gushing from the valve cover vent at the same time the power steering and 3pt start running jerky, that's the first thing I'd check.
Bob
08-01-2003 21:47:03
1.) Bad diaphragm on your fuel lift pump.
2.) Bad shaft seals on your injection pump.
3.) Bad injector.
