Tractor Talk Discussion Forum
Felt material
Chuck
07-31-2003 18:11:42
I am searching for a source of the felt material used as oil and dust seals. I have a Case VAC I am working on and can not get part VT 2730 which is a lower oil seal for the front steering pedastal.
Kelvin
08-01-2003 18:49:09
 Re: Felt material in reply to Chuck, 07-31-2003 18:11:42
My old National Oil seal catalog:
Front axle support spindle:
Dual front lower: vac s/n 5261528 &up: 450441
" upper: 472287
adjustable front, vac to 557000D vah: 472287
" vac 5570000 & up: 470605
Single front wheel: vac11 5570000 & up: 455134
These should cross to good numbers. All the MM seals I've crossed so far have gone to good numbers. Measure the ID (shaft dia.) and O.D. of your seal accurately and check these with the new seal. NAPA or a bearing supplier should be able to get them for you.
Howard Yoshida
07-31-2003 18:43:18
Aloha, Check out this site.
Mahalo,
Howard
