Tractor Talk Discussion Forum
Case sc 1946 ?
chris Goodlett
07-30-2003 17:23:35
Can anyone tell me were to look for the seriel # on a sc 1940 something case. Thank you kindly
craig in ky
07-31-2003 07:54:40
 Re: Case sc 1946 ? in reply to chris Goodlett, 07-30-2003 17:23:35
as far as that goes, you won't find a 1946 sc case, none were made that year due to a labor dispute
jal-SD
07-31-2003 06:58:16
Plate's on the dash, like the others have said, but its also stamped on the left (as you are sitting on the seat) engine flange where the engine & rear end bolt together. This is tough to find-gotta use a wire brush & scrape paint off-its stamped w/those individual # stamps, so may not be straight. It'll be something like 4809716, (which is on my '44 SC). To tell the year, subtract 4 from the first two #'s (48-4= a 44 model, for the above example) for all the V, VA, S,D & LA series made before '53. All the '53's & '54's that I've ever seen started w/80. Older C & R series & maybe L series used a different formula to determine year, but I don't remember what it is, check the Case board. (My $0.02 worth. jal-SD)
Clint Lane
08-26-2004 18:08:26
 Re: Re: Case sc 1946 ? in reply to jal-SD, 07-31-2003 06:58:16
I have an old fried who has a case tractor I believe the serial # is AC5353690. I think that this makes this a 1949 VAC case is this correct. The sheet metal and tractor are in nice shape. Needs paint but runs great. Tires are up but very weather checked. Any idea what its worth. Thanks for your help!!!!! !!!!! 1
Clint Lane
RobertTX
07-31-2003 05:30:58
Usually stamped on the flange where the engine and clutch housing mate, left side, about 2 o'clock.
Unimog
07-30-2003 18:38:07
Most old Cases had a plate on the instrument
panel with the serial number.
clint lane
08-26-2004 18:03:04
 Re: Re: Case sc 1946 ? in reply to Unimog, 07-30-2003 18:38:07
I've got a friend who has a old case. I believe the serial # is AC5353690 which would tell me that this a 1949 model VAC is this correct????? ? Thanks for your help. Any idea what its worth. Sheet metal is very good runs like a charm. Tires are bad????? ? Clint Lane
