Tractor Talk Discussion Forum
Belarus 250 AS
caroline xxxxxx
07-26-2003 17:09:23
Looking for some information on the above tractor focusing on the mechanism of the gears. We have a problem with the gears. The tractor will not go into low gear for the pto to work. Any info would be appreciated.
Belarus parts supplier
07-31-2003 02:37:15
 Re: Belarus 250 AS in reply to caroline corona, 07-26-2003 17:09:23
Find out our best prices for genuine Belarus spare parts directly from Belarus manufacturing factories in Russia, Belarus and Ukraine ....
We will beat any dealers' prices up to 30-40% ! Plus warranty and money back guarantee ...
Don't let dealers to rip you off - order directly from manufacturer when you don't need to spend more !
References from our happy Belarus customers are available on request around all over the USA and Canada.
Just E-mail us: [email protected]
Rick in R.I.
07-27-2003 21:06:01
Hi Caroline.
I have the same tractor, 1993, and although I haven't used the PTO as of yet, if i remember right I didn't have to use low gear to check the pto, I only used low engine speed.
I don't know if this has anything to do with the PTO operation? You said the tractor will not go into low gear for the pto to work. Which low gear did you try? SL1 / SL2?
Again, I don't know if it relates to the PTO, but I know that you can't access the reverse gear. If these speeds are selected in the reverse mode the tractor will not move.
Could the PTO control lever linkage need adjusting?
I'm quoting from my operators manual: 1. Depress the clutch pedal. 2. Start the engine, set the throttle to low speed. 3. Move the PTO control lever rearward to engage the PTO shaft. 4. Release the clutch pedal smoothly to start the laod. Increase engine speed smoothly to rated engine rpm.
NOTE: THE CLUTCH PEDAL MUST BE DEPRESSED TO ENGAGE OR DISENGAGE THE PTO SHAFT.
The PTO is rated at 540 rpm at 24.0 hp. Be sure not to connect equipment needing more power than the tractor horsepower rating or severe damage will result.
Best of luck.
