Tractor Talk Discussion Forum
Will a 574 w/loader handle gravel
Eric
07-26-2003 14:28:58
Just bought this unit today....(first tractor)
Wanting to get a loader for it...dealer is asking $3000 for a new 2426QT.
Thanks in advance.
Rlach
07-27-2003 18:36:01
 Re: Will a 574 w/loader handle gravel in reply to Eric, 07-26-2003 14:28:58
I do not know what a 2426QT is but I had a IH 1850 on my 574 and it has worked beautifully with anything. But just don't abuse of the front axle, the 574 has some weakness on the power steering, axle extension and spindle. By comparison the 574 axle extension/spindle is just slightly larger than one used on a Ford 8N. I had two 574 (row crop front axle) and in 17 years I have broken 13 spindles on the one equiped with the loader and zero on the other one, without loader. Axle extension/spindle of row crop front axle are longer (and consequently weaker) than those used on utility front axle. If you have the chance to own a 574 with a utility front axle, you should not have any problem using the loader, with a minimum of care.
Rlach
tbear
07-26-2003 15:50:53
Yes the 574 can handle this job mine does that kind of work all the time and i don't use a weight in the back but it could help
moonlite
07-26-2003 14:48:43
You need extra weight on back. I leave a bush hog on mine while loading. Works pretty good>
