Tractor Talk Discussion Forum
aviation tires for tractor
lj
07-25-2003 13:01:53
I've been told that using aviation tires on my tractor will help prevent the constant 'something stuck thru the tire' problem I've been having. Anybody out there doing this? Source for tires?
Scott
07-28-2003 05:48:31
 Re: aviation tires for tractor in reply to lj, 07-25-2003 13:01:53
If you can get your hands on a copy of the Farmer's Fastline, there is an ad in there every issue. Think they weren't too bad on price. I don't have a copy of the mag here, but if you need info, I'll look it up for you.
Ted
07-26-2003 19:50:50
Back in the early 80's I worked at a Goodyear Tire store. We mounted many used aircraft tires for the local Farmers. 22 ply if I remember correctly.Thay worked real well for those who had problems with thorns on there property.
stan
07-26-2003 07:44:22
I am glad I am not the only one with stuck through the tire problem. I probably average 6 each season. Last time I had one on the front, I counted around 20 patchers on the tube. I was told the tires can be filled to make them solid rubber inside. I never thought about air craft tires, might be a little pricy.
John A
07-26-2003 13:13:23
 Re: Re: aviation tires for tractor in reply to stan, 07-26-2003 07:44:22
Stan, I got my set in March of 96. Used my factory rims had the tires mounted/w new tubes. have had only "2" flats since. both were pinched tube.
I have a loader on my 966 also. I will never buy regular front tires again. The only down side of them is, In muddy conditions you will use your brakes to help steer.
I still think $140 is cheap for a tire that run you about 8 to 10 years. It averages out to about $15/year. OBTW they are 225 mph rated, and 12 ply that will always come in handy!
Later,
John A.
John A
07-25-2003 19:24:00
li, I am running a set on my 966. Love them! Just got a set for my cousins newly acquired 4230 Perfect for loader use.
This is where we got ours, We picked up @ Houston. Gensco Aircraft Tires
4300 old Spanish Trail
Houston,Texas
800-828-3350
a new 11L-15 tire/w new 6 hole rim & sealant inside $140 + freight to your place.
here, try this
07-25-2003 18:43:43
I know if you stick someting in one of those airplane tires they are no fun to fix. just what are you having trouble with?
