Tractor Talk Discussion Forum
Cub Cadet 1810 Stalling Out
STEVE SARTELL
07-23-2003 15:19:42
I have a '89 Cub Cadet 1810 with a twin 18 horse Kohler engine. Recently it has started to die out after about 5-10 minutes use. I pulled the plugs and they are white which tells me the engine is running lean. I drained the gas out of the tank without a problem and replaced it with fresh gas thinking I had a bad load of gas...no change. The fuel filter isn't clogged since the tank drained without a problem. What would cause the engine to do this? It starts fine and I sprayed a bunch of carb cleaner down the intake and the engine didn't die and was running fine afterwards. Put it out on the grass for 10 minutes and the engine guns a few times as the governor tries to keep it alive and it dies. Leave it alone for a while and it starts right up but won't run for long. Any ideas before I turn this over to a dealer which I don't want to do?
During idling, the governor has been revving the engine for some time but it always ran fine under full power. Now it dies after a short time.
Thanks for any input.
RAB
07-24-2003 00:04:12
 Re: Cub Cadet 1810 Stalling Out in reply to STEVE SARTELL, 07-23-2003 15:19:42
Sounds like the carb is clogged somewhere.
Regards, RAB
