3-PT WITH HICCUPS!!!
coy
07-14-2003 08:36:36
my long 350 has the hiccups. Does anyone have suggestions?? Thanks coy
Kens640
08-02-2003 18:37:39
 Re: 3-PT WITH HICCUPS!!! in reply to coy, 07-14-2003 08:36:36
An old wives tale : the best & quickest way to stop hiccups is to scare the ???? out of the one hiccupping . Might work ?
geok
07-14-2003 20:38:42
If you did not get any improvements from adjusting the drop control then you could have a broken retaining ring that fits around the head oring or the oring on the piston is harden with age and leaking. If orings and retainer are OK then you may have a stuck or leaking dump valve.
Rhudson
07-14-2003 19:56:31
sorry i know nothing of long and hope someone can be of more help. i guessing you're saying the 3pt hitch is bobing up and down with a load? check the lever or switch or whatever that sets the 3 pt to depth/traction/level sensoring.
let it hold its breath fo
07-14-2003 09:47:25
no text
