Need answer about operating a loader
Garry
07-10-2003 06:01:44
I have an AC WC with a loader. The tractor has been sitting for a while. I should have it running this weekend. It has a loader on it and I know nothing about operating a loader. The loader has about a 5 gal tank on it with hydraulic type line coming out of it and I need to know what type fluid goes in the tank. Someone told me it should have regular motor oil in it, but that is a lot of motor oil. Is that correct? Any additional information will also be appreciated.
TimV
07-10-2003 07:22:06
 Re: Need answer about operating a loader in reply to Garry, 07-10-2003 06:01:44
Garry: Just a couple of thoughts on loader operation in general--first and foremost, carry any load as low as possible, and don't try to turn with the bucket up high--it's a recipe for an overturn. Second, the WC is a nice little tractor, but it's neither a heavyweight nor a powerhouse. You may want to look at rear weights of some sort to keep the rear end on the ground. Good luck with the loader; they're probably the single most useful implement available for a tractor if they're used correctly.
Jim in Michigan
07-10-2003 06:13:21
should have hydraulic fuid in it, but you can use SAE 30 weight NON DETERGENT oil,,,do not use regular oil as it will foam ....use non detergent...Jim
Don LC
07-10-2003 07:07:16
 Re: Re: Need answer about operating a loader in reply to Jim in Michigan , 07-10-2003 06:13:21
Use non detergent motor oil, it will produce more pressure than hyd. oil....generally recomended for the older tractors....you will need a little more oil than it takes to fill the system when fully extended..... Tractor Supply Store has it in 5 gal. buckets..... good luck..
