Long 350 3-pt lift
coy
07-09-2003 18:31:45
I recently purchased a long 350 at auction. the little tractor runs well, but the 3-pt doesn't work properly. It will not raise completely, and will hop when an implement is attached. I have adjusted the draft control, no help. Replaced the hydraulic fluid, and cleaned the filter and the problem still exists. Can anyone offer a suggestion. Thanks coy
CAT BHL Man in Peoria
07-25-2003 18:42:41
 Re: long 350 3-pt lift in reply to coy, 07-09-2003 18:31:45
The 350 Long was a very dependable tractor. It was part of a family of Fiat designed tractors built in Romania and imported to the USA by Long Mfg. The 350, 450, 360, & 460 are very simular to the 1365 Oliver. Many parts will interchange and the service manuels are basicly the same. (from a former Oliver, White, Long dealer)
geok
07-10-2003 18:28:32
One reason for the lift not to go all the way up is because of worn linkage. Notice the small linkage between the housing and lift control arm. The roller on the linkage will wear a flat spot on it.
As for the hiccups, there is a small lever just under the seat on the right side. Turn this lever counter clockwise till it is against the stop. Looseing the center bolt just enough to bypass the stop and turn lever one more turn and see if it will help the hiccups.
