Nuffield 38TH 465 Ser.#1393/16182
David Johnson
07-07-2003 18:18:45
Problem I am Having is: The last 2 pistons are not firing. White smoke is coming out of the exhaust.
What I have done so far; put in new injectors, new injector pump, rebuilt the head.
All injectors are operating correctly, all push rods are . The valves are running correctly. Help, any suggestions. Thank You
joe
08-15-2003 00:25:24
 Re: Nuffield 38TH 465 Ser.#1393/16182 in reply to David Johnson, 07-07-2003 18:18:45
Hi David, I believe that white smoke would indicate that coolant is getting into the cylinders. Try posting a generic question related to the color of smoke from your exhaust. You will probably get quite a few responses. I have a Nuffield 3/45 that has a rough cylinder but still runs OK. My smoke is blue due to the oil bypass to the combustion chamber in that cylinder.
Good luck
Joe
marlowe
07-07-2003 20:16:31
did you do a compresion check? and i hope you changed the head gasket
