1945 H FARMALL � NEED HELP
CARL PATTON
07-01-2003 19:24:46
NEED TO KNOW HOW TO GET RADIATOR OFF.
STEERING ROD GOES THRU TOP TANK OF RADIATOR.
ANY HINTS ON HOW TO TAKE THIS OFF
RLS ia
07-01-2003 19:39:55
 Re: 1945 H FARMALL � NEED HELP in reply to CARL PATTON, 07-01-2003 19:24:46
Carl, There is a plug in the front of the bolster, take it off, then loosen the U-joint, the side towards the rad. You may have to drive a cold chisel in the slot to loosen the U-joint where it clamps to the steering shaft,. Take a pipe wrench or channel lock pliers and turn the shaft. It should screw it self out the front. Then there are two bolts with springs on them above the front wheels that are fun to get at. Good Luck.
