2wd backhoes, 4in1, mud...
Lynn Kasdorf- L
06-30-2003 11:10:13
Over the weekend I bought not one, but two Case 580B backhoes. Whichever I don't keep, my brother will buy. Many thanks to all whos gave advice on this forum. One has a simple bucket and hoe, and the other has the 4in1 bucket, extendahoe, new rear tires, and rebuilt engine. Both machines are in great condition- they have been frame-up restored and painted. They have been totally gone over by the very experienced seller, having pins and bushings replaces as needed, ram packing, etc. The simpler hoe is newer and has about half the hours of the 4in1 machine. The seller really thinks I should keep the simpler machine, primarily because of its lighter weight, and because it is less complicated, I'll be able to handle it better. (He doesn't understand why a guy that writes software all day wants a backhoe....). He kept saying "so, you have never run a backhoe??". I'm not worried about the extra complexity, except it is 3 more rams that could leak. He and another fellow gave me a couple days of lessons, and I've gotten the hang of it pretty well already and pulled some stumps and done some minor grading. Except getting stuck in the mud, it went well. I was able to lever myself out with the front bucket. I also have done the bit where you lift the rear with the hoe, and pivot the hoe, to reposition the tractor. A bit scary at first, but I can do it now. One area where I will be working a lot is a low lying forest that got flooded recently, so the ground is quite soft still. I plan to erect a couple buildings there. I've had trouble with both of these machines getting stuck in the mud. Even with new tires, it is easy to loose traction.
This will dry out over the summer, I hope! However, we do have muddy conditions a fair amount and he thinks I'll have less trouble with the lighter machine. I really see the value of 4wd now, but no way I could afford one of those. But since I have a sawmill, and for other reasons, I really like that 4in1. The extra 6' on the hoe is handy too, as I can see myself doing digging in tight spaces, and doing things like lifting trusses for a building, etc. I already did some soil moving in a place where the extra reach was very handy. So- should I go for the features or the lighter weight? I think the 4in1 will be really great for moving small logs and general cleanup, but maybe some forks on a regular bucket will do the job just as well.
TimV
06-30-2003 19:31:46
 Re: 2wd backhoes, 4in1, mud... in reply to Lynn Kasdorf- Leesburg, V, 06-30-2003 11:10:13
Lynn: Congratulations! I assume these are the machines you discussed a couple of weeks ago. I'd definitely put in a bid for keeping the machine with the 4 in 1 and extendahoe--both are VERY handy attachments, and provided they're in decent shape they will add both more functionality now and should help the resale value later. As T-bone mentioned, make sure to keep up with the maintenance--even a (relatively) simple older machine will have grease fittings in every conceivable place, plus a few others that you never would have thought of until something doesn't work. Buy manuals for whichever machine you decide to keep, if you didn't get them with the machine, and remember to keep the ear-to-ear grin off your face when the wife comes out to see why you're 2 hours late for dinner!
Jeff
06-30-2003 14:28:07
As a software guy who started with a small
JD Backhoe, I now have a Case 580c,
a KobelCO SK60 Excavator, and a TD7 Crawler.
Oh, not to forget my 15T tilt trailer, and a 5yd
dumper to pull stuff... :)
Keep the Extendahoe, they are VERY worthwhile
when you need one.
T_Bone
06-30-2003 11:51:13
Hi Lynn,
I would keep the 4 in 1. Chains are a good buy for mud work. I would also buy a 5gal bucket of grease as a backhoe requires alot of grease and often.
First I would consider which was in better shape as a backhoe is a endless money pit.
Take alook at this website. Just simply amazing.
T_Bone
CWL
07-01-2003 06:19:00
 Re: Re: 2wd backhoes, 4in1, mud... in reply to T_Bone, 06-30-2003 11:51:13
One of the local coops used the same setup to unload grain cars for a while. I never saw them get up on the train, but I did see them go from car to car. They just used the buckets to move it around.
bryan
02-24-2004 21:56:47
 Re: Re: Re: 2wd backhoes, 4in1, mud... in reply to CWL, 07-01-2003 06:19:00
MC580B. anyone know what the MC stands for in this designation for this backhoe??
OH MY GOD!!!!
07-01-2003 06:01:06
That guy has balls the size of grapefruit and a brain the size of a pea!!!
What kind of idiot would have even thought to try that!
I cant believe any company would let him do that!
ATW/WA
07-01-2003 02:23:27
T_Bone,
I've seen somethings in my time,,,,, The only reason people like that never recieve a Darwin award is that they usually take someone else's life and not there own.
ATW/WA
