New Holland 68 baler knotting problem
melissa
06-29-2003 15:13:24
we are having a knotting problem when hay is running thur the baler. We can cycle it while hanging on to the strings,(without hay) and the strings knot great, but as soon as the hay is going thur, it will not knot. we have a feeling it is something silly, but can't pinpoint it.Any help will be great.
Rick P
06-30-2003 05:57:13
 Re: New Holland 68 baler knotting problem in reply to melissa, 06-29-2003 15:13:24
Melissa I have a 68 baler and they are very picky about the twine used. I tried some 15,000 ft stuff and it would not tie. Went to 9,000 ft and hardly miss a bale. Hope this helps. Rick P
JMS/MN
06-29-2003 22:36:48
Get the OPERATOR manual for the baler- it shows knots gone bad and how to correct it.
melissa
06-30-2003 04:22:21
 Re: Re: New Holland 68 baler knotting problem in reply to JMS/MN, 06-29-2003 22:36:48
we contacted our new holland dealer in our area, he is checking to see if he can get one.
Alton
06-29-2003 16:11:20
From what you tell sounds like you need to adjust the tension on the twine. Try to adjust tension on hay chamber also. Make sure twine is threaded correctly.
melissa
06-30-2003 04:26:11
 Re: Re: New Holland 68 baler knotting problem in reply to Alton, 06-29-2003 16:11:20
Thank you I will have my husband check it out, We contacted the dealer in our area to see if they can get us an operators manual.
