Difference between moly and lithium multi purpose
Gary (Ont)
06-29-2003 05:41:45
I'm having trouble with the right angle drive gear box on my Ariens mower deck throwing out grease. The manufacture recomends using their moly based multi purpose grease but since there is no longer a dealer near by I've been using MF lithium base multi purpose grease. I've replaced the seal twice as well as the input shaft. There is no vent that I can see on the gear box. Any ideas? I already asked on the garden tractor board.
Trevor
06-30-2003 05:14:32
 Re: difference between moly and lithium multi purp in reply to Gary (Ont), 06-29-2003 05:41:45
I agree with both of the guys below. Use the Moly grease it is a better grease. But don't worry about the manufactureers grease, just go to an industrial supply house (i.e. Acklands Grainger) and take the infor from the manufacturers grease. As you said though it is just a multi purpose grease.
Now as for Howards comment, CLean out the old grease! You might have got away with using a diiferent manufacturers moly grease but now you have mixed lithium in there. you should try to clean all the grease out of the gear box and re pack it with new moly.
hope this helps.
P.S. search for info on molybdenum and lithium greases on the web and you will understand the differences better.
Howard Yoshida
06-29-2003 13:20:43
Aloha, I would use the moly grease but be sure to clean out the old grease completely which ever grease you use. Mixing greases causes trouble.
Mahalo,
Howard
mj
06-30-2003 17:58:45
 Re: Re: difference between moly and lithium multi in reply to Howard Yoshida, 06-29-2003 13:20:43
Ditto, Howard.
I seem to remember reading something years ago that stated the mixing of the two greases in question would 'lead to seal failure' or to that effect. The same was said about changing an engine or driveline components from mineral-based to synthetic when the latter first became common. :-)
Howard Yoshida
06-30-2003 19:37:44
 Re: Re: Re: difference between moly and lithium mu in reply to mj, 06-30-2003 17:58:45
Aloha, if your engine is leaking some oil now using regular oil and if you changed to synthetic oil, then it will leak more. One other thing to be concerned about too,is not to over fill with grease.
Mahalo,
Howard
Bus Driver
06-29-2003 11:57:43
My very uninformed opinion about this is that the molybdenum grease is the better of the two.
Firby
06-30-2003 07:03:22
 Re: Re: difference between moly and lithium multi in reply to Bus Driver, 06-29-2003 11:57:43
Drill a hole in the top of the gearbox 1/8 inch dia. near the back of the cover. some of the old ones didn't have a vent hole.
Steve
