Drain Plug for Case VAC Transmission Where is it??
Ron
06-28-2003 10:09:10
I want to change the SAE #90 Oil in my Case VAC transmission and cant fine where the drain plug is. The owners
book said it takes 7 Gal. of SAE #90 geer lub.I looked all over under the transmission but dont see any drain plug. Anyone know where it is located ???
Thanks
Ron
mj
06-28-2003 22:13:35
 Re: Drain Plug for Case VAC Transmission Where is in reply to Ron, 06-28-2003 10:09:10
The drain plug is just behind the left mounting bolt for the drawbar stanchion pin....lay down on your back and slide underneath the differential case and look up...if your drawbar is swung to the side you may not see the plug....swing drawbar to the right ( right as you sit on tractor)....the plug is a flush-head with a 1/2 " square drive. :-)
