Long 610
G. Baeten
06-27-2003 05:07:02
I Have a long 610 deisel tractor with a leaky water pump, which I will replace. But I did notice that when running the tractor for a short while with the leaky pump, it tended to pressurize the raditor/cooling system to the point of forcing water out the overflow. I'm wondering if there is a small head gasket leak to the water jacket causing the pressure build up?
davidval
06-29-2003 05:59:43
 Re: Long 610 in reply to G. Baeten, 06-27-2003 05:07:02
actually, a leaky water pump can sometimes draw air into the system with the engine running creating a symptom like you describe. replace the water pump then check again.
david
Howard Yoshida
06-27-2003 17:15:25
Aloha, it could be that the impeller is damaged causing the engine to overheat. Actually it could be a number of things like a bad thermostat, leaking head gasket or not enough coolant.
Mahalo,
Howard
