Oil pressure/ air filter
phillip
06-20-2003 06:39:21
what should the oil pressure be for an oliver 7o rowcrop 6 cyl? what wieght oil should be used for the oil bath air filter?
Clint
06-20-2003 08:18:24
 Re: oil pressure/ air filter in reply to phillip, 06-20-2003 06:39:21
From what I'm told the Oliver gauges were only from 0 - 15 lbs. So normal operation should fall between 10 to 15 lbs. Having variables of engine wear and such. Does this sound about right?
The oil bath filter should have the same weight oil you put in the crank case. If you're using 30W crank case oil then use 30W in the filter cup.
Another good source for questions on the web is "Ask the Oliver mechanic" Larry Harsin. Near the bottom of his web page you'll find the link to ask any and all question related to Olivers. Link
phillip
06-20-2003 09:12:33
 Re: Re: oil pressure/ air filter in reply to Clint, 06-20-2003 08:18:24
i've got 25lbs oil pressure so doing good, thanks for the help
