Help with wiring
Willy
06-18-2003 03:00:26
I need some help I am wiring a tractor that has a generator and a "cut-out". I need to see a diagram to see how to wire the "cut-out". Any help would be appreciated, Thanks Willy
Alberta Mike
06-18-2003 11:26:56
 Re: Help with wiring in reply to Willy, 06-18-2003 03:00:26
What kind of tractor Willie? Although they were pretty much all the same (assuming we're dealing with a 6V positive ground from probably the 40's or so).
Willy
06-19-2003 04:13:51
 Re: Re: Help with wiring in reply to Alberta Mike, 06-18-2003 11:26:56
Mike It is a Massey Harris but I don't think the "cutout" is standard equipment for them. It is a six volt negative ground system
Alberta Mike
06-19-2003 05:13:36
 Re: Re: Re: Help with wiring in reply to Willy, 06-19-2003 04:13:51
If it's a 6 volt Massey I'd say it was (or should be) positive ground. What model and year are you dealing with? And the cutout relay (most likely on top of the generator) was on the Masseys as well as most other tractors from the 40's and even into the 50's. Maybe email me directly at the above blue name link and we'll sort this out by email.
