Hydraulic Fluid Level 154 Cub Lowboy
Darrell Owens
06-09-2003 17:19:27
I just bought a 154 Cub Lowboy and can't find where to check/add hydraulic fluid. Can someone help?
49 Cubber!
06-09-2003 18:26:42
 Re: Hydraulic Fluid Level 154 Cub Lowboy in reply to Darrell Owens, 06-09-2003 17:19:27
Hydraulic fluid is the same as transmission fluid,check level plug is oin the back of transmission.
Herb
03-23-2004 20:15:22
 Re: Re: Hydraulic Fluid Level 154 Cub Lowboy in reply to 49 Cubber!, 06-09-2003 18:26:42
the hydraulic fluid is checked by a hex plug about 1 1/8 inch in size located on the left side behind the engine on the hydraulic tank (a rectangular casting with the cylinder mounted on the front) . I believe you can do serious damage overfilling. The operation manual should be bought.
