JD RX95 w/ 12.5HP Kawasaki
Pete
05-28-2003 12:31:39
I'm a new owner of a used RX95.
Seems to go like gangbusters for 30-40 minutes, then starts to die. Fanning the throttle into the choke zone will prevent stalling (suggesting fuel starvation) - and it will eventually recover. Or, if it dies, it starts immediately, then goes for awhile before repeating.
Could fuel shut-off solenoid act up on these?
Other possible (non-fuel) causes?
Thanks!
Steve - IN
05-28-2003 13:57:34
 Re: JD RX95 w/ 12.5HP Kawasaki in reply to Pete, 05-28-2003 12:31:39
Pete,
The fuel solenoid can get stuck. If it's stuck open, you might get some backfiring when you shut it off at full throttle. Stuck closed, fuel starvation as you say. Poor connection to the solenoid can cause it to go both ways.
Other causes --
clogged air intake somewhere along the line
the ignitor box has gone screwy Also check the valve clearance. It's .010 on mine, so even a little bit off can change things.
I've got the 620 version of that engine, assuming it's fairly similar to yours.
Eric from Valuplex
08-11-2006 16:26:01
 Re: Re: JD RX95 w/ 12.5HP Kawasaki in reply to Steve - IN, 05-28-2003 13:57:34
So how do you check and fix this this solenoid thing?
or the ignitor box?
I have the same problem: runs great for 30-40 minutes and then it just dies. You can start it right away but again it does not last. Runs great other than that.
Any step by step fixes? Does anyone know where I can get the manual for it?
Thanks
