Home built farm utility vehicle
tjw
03-27-2003 22:08:40
Looking for some info on building a small farm utility vehicle using a 10 hp -15 hp gas engine (a poor man's 'Gator'). Would be used to shift a few bales of hay or 100lb bag of feed around the place. Ease of operation similar to a golf cart (ie - just get in and go) but not as pricey. I can weld and have B & S 12 hp engine. Need some ideas and/or plans.
Any one out there ever do this or have any input? I appreciate your thoughts.
tjw
Bernie
03-29-2003 16:46:02
 Re: home built farm utility vehicle in reply to tjw, 03-27-2003 22:08:40
I have a rig along these lines I've been working on. It started out with a 2-cyl wisconsin engine that came off a highway sander, complete with a hydraulic pump, that was given to me. I wanted to use it to power my woodsplitter as well as presses in my welding shop, so I decided to put wheels on it. I had a hydraulic motor so the next step was power the wheels using a variable speed valve and provide steering. I've reached that point. I'm in the process of puting a woodsplitter valve in the system so I will have reverse as well as stopping ability. I plan to put a small forklift mast on to load haywagons,since arthritis has limited the height I can throw bales. One friend I showed it to commented that I had too much time on my hands.
Don
03-29-2003 06:28:51
I have a Kubota RX 1050 rubber tracked crawler with a 4' square box on it, check out www.dieselcrawlers.com which is where I got mine, most are in the $1500-2500 price range, they have water cooled diesel engines, and a hyd system
IMJMAC
03-28-2003 21:31:19
IF YOU REALLY HAVE TO BUILD SOMETHING I FOUND THIS ON E-BAY A WEEK AGO AND THOUGHT IT WOULD BE NEAT TO BUILD,BUT AT 60-70 HOURS A WEEK I DON'T HAVE THE TIME. THE NUMBER IS 2314223488,I THINK THE ONE I FIRST SAW SOLD FOR $26.I LIKE THE LITTLE SUZUKI.
Double R``
03-28-2003 19:28:01
I brought one of those 3pt utility carriers from TSC for 69.95 and built a platform on it with some scrap lumber that was laying around. Use it on a small tractor to move about 10bales around to feed livestock or haul feed or what ever. Works good for me.
Jerry A.
03-28-2003 08:16:44
Save some time and buy an old beater golf cart (gas powered). You could probably repower it with a bigger engine, if that's your desire or fix it up to use as is. Can't beat the bench seat (for all the kids to ride up front) and the extra room behind the steering wheel when wearing winter clothes.
I bought a used one about a year ago with lug tires on the back and a dandy little bed made of aluminum with tailgate (it looks like a dump bed, but unfortunately doesn't really dump). It is the handiest vehicle I have for running about the acreage to spray weeds and such.
MJ
03-28-2003 07:30:09
If you can find the plans for a 'Power Pup' tractor (Science & Mechanics or Popular Science.....early '60s) I think it would be just what you're looking for.....let me know if you find the plans.....I'd like to build one, too.
Cliff Neubauer
03-28-2003 05:27:11
third party image
I have a Suzuki Samuria that I use as a farm vehicle. It is bigger than you want but I bought it wrecked and have less than $500 in it after I put new tires on it. It is legal to drive on the road and with 4wd it will go pretty much anywhere. It's only 5' wide and weights in at 2,000lbs so it's not very big but it works as hard as anything on the farm.
scooterhead
03-28-2003 05:04:27
Needed the samthing , somthing to feed with . I built a platform for the back of my little massey harris 22 that was just sittin in the barn doin nothin . It gets through the mud great and will turn on a dime . Look around and find ya a little tractor , it will be alot handyer than what ya want to build and can do other work with it to .
Nolan
03-28-2003 03:39:12
Look around for a ratty rear engine riding mower. With the engine on the back, they don't get stuck easily like their front engine bretheren do. Cob/fab a bed thingie in the back out of an old wheelbarrow.
Better still, buy/get a good rear engine riding mower, then you can use it for mowing as well, and keep the number of toys down to a more manageable level.
DaveInMI
03-28-2003 03:25:35
More than one has been featured in Farm Show. There is a back issue CD available somewhere because I got one for Christmas.
KURT (mi)
03-28-2003 02:44:01
I thought of doing the same thing a few months ago and asked for advice on this board. I was going to build a 12-18Hp hydrostatic drive machine with hydraulics to run implements. But after adding up the cost ($5K) I thought I would be better off not doing it and then I built a small 13HP woodchipper instead for about $900. Besides if I would have built my own tractor it wouldnt be worth much after it was completed.
