Tractor Talk Discussion Forum
MF 245 Remote Hydraulic Control Valve
DAN YEHL
06-17-2007 13:48:40
I have a two-spool remote auxilary hydraulic valve that fit a 245 Massey Ferguson tractor. I no longer have the tractor and want to sell the valve, does anyone know what tractors would have the same remote hydraulic setup as this?
MF Poor
06-17-2007 15:11:07
 Re: MF 245 Remote Hydraulic Control Valve in reply to DAN YEHL, 06-17-2007 13:48:40
If you're talking about the type that bolted directly to the top of the rear end housing, just below the seat, that'll fit just about any Massey 100 series or 200 series, and quite a few more. How much you asking? My email should be open. I'm interested.
DALE HINTHORN
06-17-2007 13:58:21
THEY CAN BE USED ON ANY TRACTOR EVEN OPEN OR CLOSED CENTER THERE IS A LARGE PLUG ON THE VALVE . IF ITS OPEN IT WILL HAVE AN O ON THE TOP OR IT MAY BE PLAIN IF IT HAS A CC ON IT THEN ITS CLOSED CENTER.THIS PLUG CAN BE CHANGED TO EITHER AND THE PLUG CAN BE BOUGH FROM ANY TRACTOR DEALER.
Gerald J.
06-17-2007 15:15:39
 Re: MF 245 Remote Hydraulic Control Valve in reply to DALE HINTHORN, 06-17-2007 13:58:21
Its not necessarily true that the remote valve is universal. It is if its supply and return are hoses, but there has been a series of valves made for MF and Ford tractors that bolts down on top the rock shaft cover under the seat that taps the internal hydraulics and allows that to work normally or that hydraulic power to be diverted to one or two remotes with NO hoses or pipes between the tractor and the valve. Those valves are NOT universal.
Also not every general purpose valve can be converted to closed center. The least expensive valves can't often be converted. They have to be planned for conversion.
Your shift lock seems stuck, else you are shouting and that's not necessary in this forum.
Gerald J.
