15-40 oil Total Base Number HELP
d3,Mike
11-08-2002 22:35:44
Hi, I would appreciate your views on the high TBN numbers used in most diesel oils used today. I understand that emission controls and longer change intervals make this a requirement. The problem is that I have a newly rebuilt, 1964 Perkins A3-152, that idles a lot and seldom sees much throttle. I also use .05% diesel.This throws the old TBN rule of thumb of about 20 times the sulfur content, for indirect engines, out the window! I know that Cat warns about cylinder polishing and loss of oil control when using a excessively high TBN. and I have heard of other older diesels loosing oil control when the new CI-4 oils are used in engines that do not see a lot of heavy load. So, any thoughts on how high a TBN can be, before it is to high? Also what is a reasonable limit on ash? I would like to use 15-40. Any thoughts or recommendations on my problem would be greatly appreciated! Thank You for your time, Mike [email protected]
And yes I did contact Perkins in England, they recommended API CC , I told them that CC was obsolete by about 15 years and they said that they could make no further comment on the subject!
payman khabbazpour
10-15-2003 03:52:52
 Re: 15-40 oil Total Base Number HELP in reply to d3,Mike, 11-08-2002 22:35:44
hi dear
i want information abaut fall of tbn of oil vs kilometrage of use that oil and abaut tan similar thanks for your helping
Mobil Delvac 1300
11-09-2002 08:32:58
Use Mobil Delvac 1300 15W40. It is better than Shell Rotella and Chevron Delo.
d3 Mike Thank You
11-14-2002 00:54:28
 Re: Re: 15-40 oil Total Base Number HELP in reply to Mobil Delvac 1300, 11-09-2002 08:32:58
Thank You. Mike
