Case 220-224 Lawn Tractor
John O'Brien
07-29-2002 20:50:41
I have a 222 with a blown engine (a 14 hp Kohler) and found a parts tractor, a 220. I was hoping someone would know what size engine might be in this machine and also if anyone knew the finer points of pto clutch work on these Case machines. I put a new pressure plate on it a few years ago but haven't been able to get it adjusted to my liking (if i get it tight enough it slips into gear and I have to bungy the engage handle back). Thanx for any and all help.
DRR
07-30-2002 17:25:27
 Re: Case 220-224 Lawn Tractor in reply to John O'Brien, 07-29-2002 20:50:41
The last no. in the model is the hp.Example 220 is 10 hp,448 would be 18 hp. and yours should be a 12 hp.PTO clutches are tricky and time consuming to adjust.If you plan on keeping the tractor you might check into installing a ez adjust clutch from an Ingersoll dealer.These came on the later Case models and make adjusting the clutch a 2 minute job.
Randall
05-02-2004 08:50:11
 Re: Re: Case 220-224 Lawn Tractor in reply to DRR, 07-30-2002 17:25:27
I have just recently bougth a 1967 case 224 with tiller,deck and snow blade I was just trying to find out more about this and where to get parts if i ever need any. Any information would very helpful
