Seamon Tractor?
Bob M (w/pix)
05-26-2002 06:49:19
Anyone out there ever heard of a Seamon Tractor? I hadn't until yesterday when I stumbled over this one (punch below for pix).
Looks as if it was intended for construction or possibly tug use. However the frame, tires, differential and rear axle look awful light for a tractor with 130 - 140 HP motor (Detroit 4-71). Also the hydraulic system appears minimal - pump is single belt driven off the crank pulley.
One thing is for sure: It's a screamer when it get's cranked up!!
SEAMO
06-01-2002 11:33:00
 Re: Seamon Tractor? in reply to Bob M (w/pix), 05-26-2002 06:49:19
Bob M. This real interesting to me because, my last name is SEAMANDS Others who broke from the family spelled it Seaman Seamon Seamonds the picture shows it to be Seaman Tractor. Where was it built? Earl Seamands Mahomet, Illinois
Hal/WA
05-27-2002 13:21:19
It sure looks like the manufacturer used a lot of off the shelf truck parts from the era--the engine, probably the transmission, the front axle and leaf spring suspension. There probably was a choice of a number of engines that would fit the chassis. I am not familiar with that rear end, but outwardly,it is about the size as medium trucks had then.
Some of the posters mention rototillers on these tractors. I did not see a PTO shaft in the photos. Is the PTO handled by an add-on case bolted to the side of the transmission case? To do rototilling, a tractor has to move very slowly. How is the slow speed acheived, through transmission gearing, or are the rear gears way steep, like 10 to 1?
Your tractor, though done much more professionally, reminds me of a homemade tractor some friends made out of a 40's International 1.5 or 2 ton truck. The front end was intact with the hood covering the original engine and front axle. The cab, which had been ruined in a roll over was cut off and the frame was shortened to long tractor length and the truck rear end with duals was mounted solid to the frame. To get it to go slow enough for tractor work, a second 4 speed transmission was mounted just behind the original 4 speed and a very short driveshaft mounted to the rear end. A huge block of concrete had been cast above the rear end for traction and they always left the duals chained up. In compound in both transmissions, the machine would go extremely slow, and as we found, in high in both transmissions, it was scary (and dangerously) fast! The brakes left a lot to be desired though. We had a lot of fun with it and they did their heavy pulling with it for years.
big diesel
05-26-2002 18:37:02
i have a older Seaman tractor, has a six cyl. gas flathead with 13.6x38 tires and 9 bolt wheels. Been setting for 6 or 7 years. Any offers? was going to make a tractor puller but don't have the time
PLT
01-03-2007 15:07:15
 Re: Re: Seamon Tractor? in reply to big diesel, 05-26-2002 18:37:02
I might be interested. Please send more information. Thanks
Patrick
John Ne.
05-26-2002 14:31:51
Interesting, I can see the front wheel is a standard truck rim, and the rear axle sure looks like a 40s Ford 1.5 ton that I'm familiar with. john in nebr.
Larry from Maryland
05-26-2002 08:09:17
They where ment to operate a rear rototiller.I have seen a few and it allways seems the tiller wears out much faster than the engine and tractor.The tiller gets disscarded and all you useually find is the tractor.
CDH
05-27-2002 03:18:23
 Re: Re: Seamon Tractor? in reply to Larry from Maryland, 05-26-2002 08:09:17
Bob I operated one of those seamond tillers backin the 50's it was 6 cyl. gas had 8 ft rotiler used it to till up spinage beds for winter cuting no power steering back then poor seat made to stand up to operate my experence with puppy later CDH
CDH
05-27-2002 03:17:34
Bob M
05-27-2002 06:18:17
 Re: Re: Re: Seamon Tractor? in reply to CDH, 05-27-2002 03:17:34
Thanks to all for the info! Would like to have seen one of these set up for tilling. ...Bob M
