4WD could be used only if i have Multipower switch in LOW position
1080 with 4WD
05-26-2002 05:05:18
Hello!
I have problem with 1080 and 4WD (year 1972). I have Multipower version and 4WD clutch is controlled with
the same oil used for multipower.
Now the problem is that I cannot use front wheel drive if I switch Multipower to HIGH (engine breaking).
If I switch Multipower to LOW 4WD is working but if I go downhill, the engine is not breaking.
Does someone know is this is normal circumstances.
My opinion is that oil pump doesn't have enough power to supply oil for both clutch.
Please help!
Thanks in advance
Dusan
DaCcAd
10-08-2005 23:26:27
 Re: 4WD could be used only if i have Multipower sw in reply to 1080 with 4WD, 05-26-2002 05:05:18
i ran across this old post on the mythic MASSEY FERGUSON 1080 with 4WD. I"ve been trying to find some info and a PARTS MANUAL for for one . do you think you can help me out on my quest ? is it a factory option or a Selene 4wd conversion ? are the parts still availiable from the company . Ihave a MF1080 that I would like to make into a 4WD . THANKS FOR ANY HELP YOU CAN SEND.
Woodbeef
05-27-2002 04:15:01
 Re: 4WD could be used only if i have Multipower switch in LOW position in reply to 1080 with 4WD, 05-26-2002 05:05:18
Hhmmm....you must either have a French built tractor,or an aftermarket front axle(Selene possibly)We never had a mfd 1080 available new in N.A. except maybe in Quebec (I've seen mfd 265 and 275 there)Check the AgDealer for Massey dealers in Quebec,and contact some of them,they might just have an answer for you.
Dusan Kuster
05-27-2002 04:21:28
 Re: Re: 4WD could be used only if i have Multipower switch in LOW position in reply to Woodbeef, 05-27-2002 04:15:01
Yes, it is French version. It looks like front axle is Factory mounted with 28" tyre.
It's very powerfull and I use it in forest with 6 ton winch.
Thanks
Craig MO
05-26-2002 16:33:49
The multipower system will coast when going downhill this is the way all MF's are. They must be in the high side to have engine breaking. If the 4wd is plumbed into the low side it would not work when in the high side. I have never worked on 1080 with 4wd so I can't tell you how it is supposed to work, I just know how the multipower works.
