Tractor Talk Discussion Forum
1969 Massey Ferguson (gas) PTO Low power NEED HELP
Mary J
06-16-2007 14:39:38
Hello....Hay cut & Raked...hydraulic fluid filled...hoses checked - PTO has LOW Power...Need help - Horses need fed!
Thanks
Mary
Bob N.Y.
06-16-2007 16:27:26
 Re: 1969 Massey Ferguson (gas) PTO Low power NEED HELP in reply to Mary J, 06-16-2007 14:39:38
What model tractor? Does it have "Live PTO" (2-stage clutch) or "Independent PTO"? We need a little more info to diagnose the problem.
Mary J
06-16-2007 19:27:55
 Re: 1969 Massey Ferguson (gas) PTO Low power NEED HELP in reply to Bob N.Y., 06-16-2007 16:27:26
Massey is Model 175...PTO is Live.
Under any pressure it just stops :(
Any help would be great as have to feed the horses!
Thank you
marlowe
06-16-2007 20:09:11
 Re: 1969 Massey Ferguson (gas) PTO Low power NEED HELP in reply to Mary J, 06-16-2007 19:27:55
if it's live PTO then your clutch pack is gone or your pump is weak . if it's a two stage clutch then you clutch is going or is out of adj.
Mary J
06-16-2007 20:53:45
 Re: 1969 Massey Ferguson (gas) PTO Low power NEED HELP in reply to marlowe, 06-16-2007 20:09:11
How do you determine if it is a "2 stage clutch?"
Noleaks in the hoses...hydraulic fluid is at proper level...the PTO is turning
With the PTO turning - does it help to diagnose better?
Thanks for helping Any help is appreciated.
Mary
Bob N.Y.
06-17-2007 13:22:22
 Re: 1969 Massey Ferguson (gas) PTO Low power NEED HELP in reply to Mary J, 06-16-2007 20:53:45
Two stage clutch means you push the pedal half way down to stop the ground travel and all the way down to stop the pto (Live PTO). If you can engage the pto without using the clutch pedal, that is "Independent PTO". Marlowe is confusing the terms.
RayP(MI)
06-16-2007 18:42:52
Going to venture a guess here he may have a ground speed option on his PTO, many Masseys did. The PTO selector had three positions, engine drive, off, and ground drive. Suggest he should check and see if that's the case, and he has PTO selector in the wrong position.... Sorry, been a while since I've been on a MF, and can't remember which position is which! Stand to inherit a MF in the near future, and I get to find out then!
