Ferguson TE20 distributor parts
Al Kurzawski
02-01-1999 10:18:29
Does anyone know if distributor caps, points, rotor, condensor and spark plug wires are available new from any source. I have a 1948 with the screw on type plug wire end at the cap end of the wire. Thanks
Major Al, USAF
TERRY
06-29-2004 13:48:23
 Re: Ferguson TE20 distributor parts in reply to Al Kurzawski, 02-01-1999 10:18:29
I JUST BOUGHT A TE20 A COUPLE OF WEEKS AGO AND GOT PARTS FOR THE LUCAS DISTRIBUTOR FROM TRACTOR PARTS.COM THEY ARE ON THE EAST COAST. NOT TO BAD ON PRICES EITHER.
Jim
02-08-1999 09:37:50
Check "Leesburg Tractor Parts" also.
1-800-426-6960 in Leesburg Indiana.
I've purchased several parts from there
for my TO30. Asked if they are used or new.
Tex Ferguson
02-03-1999 18:41:31
My '49 model TE20 has the Delco distributor from the TO20, installed by a previous owner; it also has negative ground. Ignition tuneup parts are available from NAPA at very reasonable cost, compared to the Lucas kit from a MF dealer. If you install the Delco and stay with the original positive ground, you might need to reverse the polarity of the condensor, but the points don't care which direction the electrons are jumping.
Good luck!
