Tractor Talk Discussion Forum
kubota L245
inspector101
06-14-2007 14:05:07
how do you check the transmission fluid level?
what other types of fluid can be used besides the kubota UDT?
ScubaInstr
06-15-2007 11:09:59
 Re: kubota L245 in reply to inspector101, 06-14-2007 14:05:07
I have a 1978 L225, and the hydraulics, transmission, and rear end all share the same fluid reservoir. I assume yours might be similar.
On mine, you pull out a filler bolt and you should see fluid. It is located on the left-front of the transmission, above the clutch petal.
HTH....
Tommy D.
