Tractor Talk Discussion Forum
rear axle rim 400 M the same ? IH
roger roland
06-13-2007 09:18:45
just wondering if the center red cast part off an M will fit a 400 ? or are they diff ?i need one for a 400 & have extra M ones
Wardner
06-13-2007 19:19:55
 Re: rear axle rim 400 M the same ? IH in reply to roger roland, 06-13-2007 09:18:45
You need the six spoke wheel. Early 400's had them. The later 8 spoke cannot use the earlier rim.
roger roland
06-13-2007 15:02:06
Thanks guys that atleast tells me what to look for or i would have just try'd & wasted alot of time if they are diff
Carp
06-13-2007 09:53:50
Yes the center cast hub will fit between the two tractors. You just have to be careful of the rim as Old mentioned. Most of the 400 and up tractors used a double bevel rim and the SMTA down used a drop center rim. You still have to be careful and check, because a lot of things have switched around over the last 60 years or so.
old
06-13-2007 09:41:47
Can't say for sure but I know they are different on a 560 and an M. I just picked up a pair of rims off a 560 and because the M uses a drop center type rim they will not switch out like we had hoped they would
