monroehillfarm
New User
Ok so I have tried everything I know possible. I ordered the complete 12 volt upgrade for my Ford Powermaster 841. Replaced the following parts on the tractor. Alternator, Coil, Solenoid, and a 12 volt electronic ignition to replace the distributor condenser and points. I have wired the system back according to the 12 volt upgrade diagram supplied by yesterdays tractor. The only difference I really see is that I went from a three post solenoid to a four post.
So after all that here is my issue. The original starter button will no longer start the tractor. Top lug to battery bottom lug to starter S to original push button and I to key switch power. Nothing happens when button is pressed. Have removed wire from the button and applied it straight to ground and still nothing. If I take the wire off the I and put it on the S then it will turn the tractor over, but it will just continue to turn it over until the key is turned off. I would assume that s because it is feeding co start 12 volt to the solenoid.
I was thinking maybe a bad solenoid, but went to tractor supply and bought another 4 post 12 volt for ford 801 and same result.
Can someone please help with this
