Tractor Talk Discussion Forum
Hyd pump
Matt Bunsen
06-12-2007 13:47:28
I have a 69 4520 with the synchro trans,I just installed a reman hyd pump and set it to the proper pressure. The old pump was very noisy.The problem that I have is that the pump doesn"t supply pressure right away.The old pump did the same thing. You have no brakes,three point or supply to the remotes, but after a couple of minutes the pump kicks in and it also vibrates the tractor.Does anyone have any solutions and how hard would it be to fix.Thanks for the info.
dds-inc
06-12-2007 13:54:19
 Re: Hyd pump in reply to Matt Bunsen, 06-12-2007 13:47:28
Might be the in-transmission pump. I bet a dollar something is wrong with it. It is the ONLY thing that provides the tractor with main pump oil flow.
