Ferguson Fe-35 Gasoline engine
Friedhelm Hamhu
11-11-1998 11:16:35
Hello.
I purchased a FE-35 with gasoline engine last weekend. I´ve got one little problem:
This engine uses gasoline and here in germany only unleaded gasoline is available. Can i use this or is it better to ad lead-additives to it?
Thanks
Friedhelm
Gerald
11-12-1998 18:33:53
 Re: Ferguson Fe-35 Gasoline engine in reply to Friedhelm Hamhuis, 11-11-1998 11:16:35
: Hello.
: I purchased a FE-35 with gasoline engine last weekend. I´ve got one little problem:
: This engine uses gasoline and here in germany only unleaded gasoline is available. Can i use this or is it better to ad lead-additives to it?
: Thanks
: Friedhelm
That tractor was built in an age when lead was something new to gasoline primarily to raise octane, not as a valve lubricant. It won't hurt the engine to use unleaded fuel, but most lead substitutes are not great at valve lubrication. The engine should already have hardened valves and valve seats. Plugs will last longer with unleaded gasoline and the whole fuel system will probably stay cleaner with unleaded fuel.
And while you are at it, use a modern high detergent oil, say a high quality 10W30 instead of the straight weights recommended 50 years ago. The modern oils are far less prone to gumming and corroding bearing inserts and lubricate better all around. They also tolerate condensation better and keep the engine much cleaner inside.
Gerald
Woodbeef
11-12-1998 16:43:16
If the motor does not smoke,I'd use either lead substitute or change the valve seats to hardened ones.
Mark
11-11-1998 13:44:51
: Hello.
: Thanks
: Friedhelm
Unleaded is fine - no additives needed. Besides, it burns cleaner.
buckies
11-22-1998 00:05:43
 Re: Re: Ferguson Fe-35 Gasoline engine in reply to Mark, 11-11-1998 13:44:51
: : Hello.
: : I purchased a FE-35 with gasoline engine last weekend. I´ve got one little problem:
: : This engine uses gasoline and here in germany only unleaded gasoline is available. Can i use this or is it better to ad lead-additives to it?
: : Thanks
: : Friedhelm
: Unleaded is fine - no additives needed. Besides, it burns cleaner.
