'65 Int Cub
Daryl
11-01-1998 15:31:37
When I pull my small homemade drag, after about 5 minutes of pulling my engine seems to slowly "spit and sputter" and then die. It is not the size/weight of the drag. When I run the tractor alone, it runs great. Could it be something with the carb or cylinders? Please advise.
crow
11-02-1998 06:30:51
 Re: '65 Int Cub in reply to Daryl, 11-01-1998 15:31:37
: When I pull my small homemade drag, after about 5 minutes of pulling my engine seems to slowly "spit and sputter" and then die. It is not the size/weight of the drag. When I run the tractor alone, it runs great. Could it be something with the carb or cylinders? Please advise.
Had the same problem,try cleaning bowl on carb,an make sure your fuel line is not mashed together.A tractor may run fine without a load,when put under a load your govn picks up an the engine needs more fuel.
