Tractor Talk Discussion Forum
Ferguson model TO-20 cracks in block
Bill in Nampa
06-08-2007 08:41:13
First time tractor Mechanic...Help! Hairline cracks between inner cylinder walls...is this common? Is it a problem? Thanks
Bill
J Schwiebert
06-08-2007 08:45:35
 Re: Ferguson model TO-20 cracks in block in reply to Bill in Nampa, 06-08-2007 08:41:13
At the top of the block or at the bottom of the block? If this is between #1 & 2 sleeve and then 3 & 4? With your description you gave you should be good to go. Now if the cracks are on the bottom that is another matter. Questions? J.
Bill in Nampa
06-08-2007 09:19:56
 Re: Ferguson model TO-20 cracks in block in reply to J Schwiebert, 06-08-2007 08:45:35
J,
It appears there are cracks on the bottom also, between cylinders. What now?
Thanks,
Bill
Jerry/MT
06-08-2007 21:17:44
 Re: Ferguson model TO-20 cracks in block in reply to Bill in Nampa, 06-08-2007 09:19:56
Not an uncommon occurance on a Continental Z block. It usually occurs due to overheating. Try to find a shop that know where you can get it furnace brazed and you'll be good to go. You can sometimes find used blocks on ebay. Midwest Cylinder Head (www.midwestcylinderhead.com) repairs castings.
