'40 Farmall H
mark stanfield
07-12-1998 05:12:09
"exhaust cough" at idle. Does not occur under load.I've replaced plugs, carb clean & kit, new wires, compression 150 -155 across all cylinders. Runs great & clean under load like bushog or plow. Any suggestions?? Please help.
Milan
07-12-1998 23:09:16
 Re: '40 Farmall H in reply to mark stanfield, 07-12-1998 05:12:09
: "exhaust cough" at idle. Does not occur under load.I've replaced plugs, carb clean & kit, new wires, compression 150 -155 across all cylinders. Runs great & clean under load like bushog or plow. Any suggestions?? Please help.
Have you checked your distributor advance? Could be staying advanced in timing at idle. The two small springs could be disconnected from the weights, or excess wear. Check the timing with a timing light if available.
Older tractors often loose the benefit of the automatic timing advance for faster engine speed, and an engine will run good on one end of the scale but not the other.
Send me a direct email if you might want a few of my ideas on how to get the timing set easily.
John Fritz
07-12-1998 09:21:30
Mark, tried your E-mail address but got "damion". Check your manifold for leaks. Had a similar problem on a 41H and it was a bad manifold gasket.
