Tractor Talk Discussion Forum
overcharging-now no charge
larryinwa
06-06-2007 13:05:08
posted on garden tractor page,not much luck,so try here.have a wisconsin engine with starter/generator,was overcharging so put on new regulator,now no charge at all.have wiring diagram so know all wires are right. any ideas? thanks
larryinwa
06-06-2007 20:24:05
 Re: overcharging-now no charge in reply to larryinwa, 06-06-2007 13:05:08
yes,i did polarize.
Bob
06-06-2007 20:28:11
 Larry... in reply to larryinwa, 06-06-2007 20:24:05
Did you read my post... polarizing beyond what happens in "start" mode isn't needed, not can it POSSIBLY help.
Did you "full-field" it as I suggested... that will "tell the tale" as to what is wrong.
Bob
06-06-2007 13:47:43
Try "full-fielding" it by grounding the "F" terminal on the starter/generator.
If it then charges, the regulator is bad, not grounded, or there's a wiring problem.
Bus Driver
06-06-2007 13:43:16
I am not familiar with that particular machine. The comment below about polarizing is correct for generators. Alternators must never be polarized. Any attempt to do so probably will do serious damage.
chrisfromsolitude
06-06-2007 13:19:23
Did you polarize the generator after you put the new regulator on?
Bob
06-06-2007 13:48:47
 Re: overcharging-now no charge in reply to chrisfromsolitude, 06-06-2007 13:19:23
Chris,
Since it is a starter/generator "combo" it is, in effect, polarized every time the starter is used.
